Cat converter question
Old Aug 5, 2007 | 06:18 PM
TTsteve's Avatar
Default Cat converter question
With a 2.5 inch stock exhaust, would it be a good idea to just buy a highflow cat and cut out the old and replace it with the new? Or is there more to it than that? Dont feel like spending about $1800 on a new exhaust as the stock one should flow good and even better if I can replace to restrictive cat. Know any good places? Thanks.
Old Aug 5, 2007 | 06:27 PM
cincyTT's Avatar
I'm make believe
Default RE: Cat converter question
The mkI cats are pretty high flowing as is, guessing the mkII are as well. If you want more i would make a race pipe section and swap between the two as needed.
Old Aug 5, 2007 | 06:36 PM
TTsteve's Avatar
So do you think I need an exhuast upgrade for the MKII? Was looking for a good DP but the only out there so far is Milltek at $900 just for the dp w/cat.
Old Aug 5, 2007 | 07:03 PM
cincyTT's Avatar
I'm make believe
You wouldnt have a pic of the stock exhuast or comparo pics would you?
Old Aug 5, 2007 | 07:21 PM
TTsteve's Avatar
I can try some tomorrow but I think the stock one is about 2.5 most of the way from what I have read. I have $1000 for mods right now and the chip is about $600 (hoping to not have to get a DV), and was hoping to do the 2.75 inch DP to stock catback with the other $$$ or replacing existing cat but if they flow good then wont have to do that. But 2.75 DP should help without losing low end torque I think.
Old Aug 5, 2007 | 07:33 PM
cincyTT's Avatar
I'm make believe
The milltek one was pretty straight so you would assume so is the stock peice but i know better. If the stock peice spits into 2 like a quattro dp or and kinks, extra bends, or reduce in size i would swap it.
joeyac02
Feb 11, 2012 06:33 PM
strikingviking
Sep 7, 2011 01:31 AM
RyanSweeney
Jan 4, 2011 10:25 AM
NCS2073
Mar 2, 2009 06:21 PM
auS4di
Jan 11, 2008 02:49 PM
