Catch Can
Old Oct 21, 2007 | 02:16 PM
  #21
cincyTT's Avatar
I'm make believe
Default RE: Catch Can
Greddy and other $100+ cans will have baffles and the Ebay kits are just empty tanks.
Old Oct 21, 2007 | 09:42 PM
  #22
tom1222's Avatar
This one looks like it has an inline filter that may prevent the oil from passing on.
http://cgi.ebay.com/ebaymotors/ws/eB...NA:MOTORS:1123
Are those things hard to mount? I mean there is hardly any room in that engine compartment to start with.
I got this reply when I asked about if their catch can has a check valve or filter:
Dear Sir,
The vapors and gases will condense in the oil catch tank. The changes in pressure and temperature will aid in this process. If the tank is near its capacity, then there is danger that the contaminants will be leaked into the intake.
Please contact us if you have more questions or require further assistance.
So I guess it doesn't have one but they think it is not going to be a problem.
Old Oct 21, 2007 | 10:11 PM
  #23
cincyTT's Avatar
I'm make believe
Thats the same one as posted before. You can mount it anywhere, youll just have hoses everywhere. Just look at my first pic, its simple clean and hidden by the engine cover if you run one.
Old Oct 21, 2007 | 10:15 PM
  #24
tom1222's Avatar
ORIGINAL: cincyTT
Okay, one more question. Which type of size fitting should I get? They seem to come in 9mm and 15mm.
Old Oct 21, 2007 | 10:52 PM
  #25
cincyTT's Avatar
I'm make believe
15mm
Old Oct 21, 2007 | 10:58 PM
  #26
tom1222's Avatar
ORIGINAL: cincyTT
15mm
Thank you!
Old Nov 19, 2007 | 02:12 PM
  #27
ouTTie914's Avatar
Bump to end IAT sensor oil build up!
...Should have done this a long time ago! [>:]
Old Nov 19, 2007 | 02:27 PM
  #28
cincyTT's Avatar
I'm make believe
really?
Old Dec 11, 2007 | 05:05 PM
  #29
Anos's Avatar
Figured id add the part # for the Husky.
Home Depot #HDA70400AV[*]Removes unwanted dirt particles and condensed water to extend tool life.[*]5-micron element.[*]Screw on bowl with manual drain.[*]1/4 In. NPT (Female) ports.[*]21 SCFM flow capacity @ 90 PSI.[*]MFG Brand Name : HUSKY[*]MFG Model # : HDA70400AV[*]MFG Part # : HDA70400AV[*]$11.97 EA
[/ul]
Old Dec 11, 2007 | 05:16 PM
  #30
cincyTT's Avatar
I'm make believe
lowes has there own line they carry and comes in the smaller size like i have above and larger for a few $ more. Comes with a blue topand the fittings are all the same.
I dont know how long the filters last unfortunatly. Also i am unable to find just the filters for sale. So worse case you may have to buy a new can and filter about every 12mos is what Andrew and i figure.
