changing brakes need help
I am changing the bakes on my tt and the front brakes have these sensors , am i suposed to use the old sensors on the new brake pads? i am having trouble removing the sensor from the old brake pads
any advice?
I am talking about the elctronic sensor. that plugs into a wire.
any advice?
Don't worry about it. Just make a wire loop and tape it into the connector to connect the circuit. The sensor is just there for people who never check their brake pads. You should check them everytime you rotate your tires (5000 miles) anyway.
ORIGINAL: branstone
the box shoes the sensor though.
oh SHOWES...well they should have come with them mine did...but they just pull out of the hold ones..cut them out with a saw if needed
hah ha yea shows the sensor. i ended up just looping the wire that connected to the pads, next time maybe ill get the sensors i guess its no biggie
thanks
brakes are all done.at least the fronts, the backs still look almost new.
thanks
