chip tuning, is it worth it?
Old May 19, 2007 | 07:52 AM
megamoe's Avatar
Default chip tuning, is it worth it?
hello everyone,
i am new to the whole Audi TT world and was reading all about chip tuning, i was wondering is it worth it? cause where i live it'll cost me around 750$ to do the tuning and was promised an increase of14%. will it cause overheating by anyway ?
thx alot
Old May 19, 2007 | 08:28 AM
achTTung's Avatar
Default RE: chip tuning, is it worth it?
$750... ouch.
Which chip tuner did you have in mind? If they have a website, check it, and it'll tell you exactly what you're getting.
Overheating? Doubt it.
Old May 19, 2007 | 10:18 AM
stephenson27's Avatar
I ended up spending $750 on mine because REVO hosed my ECU with their trail program and then I decided to purchase GIAC so that basically included a new ECU. Are you purchasing another ECU with the program or getting yours flashed? If you're getting it flashed then use one of the shops that offer it through the mail and save yourself $300 bucks. You can rent a low end eco car for 3 days if you need to and still come out ahead.
Are you talking about the engine actually overheating or the turbo getting heat soaked?
Old May 19, 2007 | 12:33 PM
cincyTT's Avatar
I'm make believe
chips will give you 20-30hp and 30-40ftlbs
Also the engine will run fine, turbo will be fine, just that the intercooler will be heatsoaked much faster and often and the stock dv will wear faster due to the extra pre-ic heat and crappy location.
Old May 19, 2007 | 07:38 PM
timbo108's Avatar
Most tuners I checked with charge about $495plus$50 labor to bench flash your ECU while you wait. Add another $100 each or so for multiple programs.
Old May 20, 2007 | 01:24 AM
megamoe's Avatar
They donthave overseas tuning for my area, the only shop that we got over here is this:
http://www.chipcentric.net/
Old May 20, 2007 | 01:42 AM
neur0tic's Avatar
Overseas where?
Your other option is to either remove your ECU and overnight it to GIAC, REVO, APR etc... and have them overnight it back; or... you could pay an additional couple hundred dollars and just order a preloaded ECU, have them mail it to you; and install the ECU yourself. It really isn't hard to install.
JETSPEED333
Jan 19, 2011 04:37 PM
leon1977
Mar 23, 2009 05:41 PM
leon1977
Feb 18, 2009 09:53 AM
andrew7173
Mar 28, 2008 12:46 PM
m5racer
Jul 27, 2006 05:36 PM
