chugging noise
Old Jul 15, 2008 | 07:19 PM
jhsoccerodp's Avatar
Default chugging noise
i have a chugging and notchy rpms when i am past 3500 in any gear, but when in neutral its just fine which leads me to believe it is something with the transmission. I dont think something is totally wrong with the transmission but at first i thought it was the turbo, but that would do it in neutral right?
Any input?
Old Jul 15, 2008 | 07:53 PM
ouTTie914's Avatar
Default RE: chugging noise
Do you have a boost gauge? If not, go get one!
Old Jul 15, 2008 | 09:02 PM
myslow1's Avatar
ORIGINAL: ouTTie914
lol the solution to all problems.
i still dont have one
Old Jul 15, 2008 | 09:19 PM
SeaTTle's Avatar
I am experiencing a wierd flutter at half throttle which I think is due to being at half throttle and coming up on more speed and less load. Is this normal or what you are experiencing? I have a boost gauge and it's showing up to five and dropping off. If I WOT, it's 15.2 peak and dropping. I think i have a sticking DV. Do you think you could be experiencing a need for service on your DV?
Old Jul 15, 2008 | 10:33 PM
i have a aftermarket diverter valve what is a way to test if its going bad or not, because i made some adjustments to it and didnt notice anything different and then all the sudden i did like the next time after driving it. But wouldnt the dv still be blowing off boost in neutral?
Old Jul 15, 2008 | 11:59 PM
exTTreme's Avatar
you only make 5 PSI in nuetral
Old Jul 16, 2008 | 12:12 AM
sounds like it could be dv then can i take it off and clean it or what do i do sorry im switching from an m3 and 325 to a turboed amazing machine, the type i have is in my sig
Old Jul 16, 2008 | 12:46 AM
exTTreme's Avatar
Here is the link on servicing the Forge DV not sure how similar your turbosmart one is
Turbosmartonline.com has instructions also but Im not sure which model you have so I'll let you browse and find the link that matches your DV
Old Jul 30, 2008 | 11:46 PM
i now have a boost gauge and am running high on boost. In first and second i barely see much maybe 10 at the most but in 3 4 5 and 6 i see 20 sometimes. The car doesnt seem to be chipped. What could cause this? N75 or wastegate?
Old Jul 30, 2008 | 11:49 PM
also it is constant through 1st and 2nd gear but only in higher rpms in 3rd and up. Only happens under moderate to heavy acceleration.
