clutch question
Old Dec 12, 2007 | 09:48 PM
  #31
theTTkid's Avatar
Default RE: clutch question
ok, last question, where is a good place for a 12-14lb steel FW?
Old Dec 12, 2007 | 09:56 PM
  #32
cincyTT's Avatar
I'm make believe
Havent look completely around, but mjm sells a 7lb and ecs sells a 9lb. Dont know what others are running
Old Dec 12, 2007 | 10:26 PM
  #33
theTTkid's Avatar
but i dont want chatter
Old Dec 12, 2007 | 10:31 PM
  #34
cincyTT's Avatar
I'm make believe
find out what Andrew and Erin run with their spec 2+ kits. Dont think they claim theirs chatter to much
Old Dec 12, 2007 | 10:51 PM
  #35
theTTkid's Avatar
haha sorry, im not like ryan and dont know people by name haha... what are their login names?
Old Dec 12, 2007 | 11:07 PM
  #36
cincyTT's Avatar
I'm make believe
meanaudiA6 = Andrew
225TT = Erin
Sorry, i talk to them often and post their names. Kind of like they do mine
Old Dec 13, 2007 | 01:32 PM
  #37
MeanAudiA6's Avatar
yup go with a spec stage 2+ and billet steel flywheel and raise idle to 950-1000rpms. this will vary if you go with a Alum FW. they chatter a lot compared to the Steel.
ya me nate,erin and matt often use each others names...like bros.
Old Dec 13, 2007 | 01:55 PM
  #38
tom1222's Avatar
ORIGINAL: DEDMN_TT
while we're on clutches, what's the reasons for a clutch catastrophically failing? (basically replacing virtually the whole assembly)
I had to ride with someone for a bit so i left my car at work with a "friend" so he can get a bite to eat for lunch. I come back and the car's on the side of the road 2 miles from work. He said the car just started revving hing and finally it won't drive. He drives a ford ranger stick so I figured he knew his way around the clutch. I got it all fixed but never really know why my clutch would just crap out like that. The car's at ~61k miles when it happened. To this day, I don't know if I should kick his *** or the clutch just happen to go out on his shift. I drove to work fine that day, by the way.
Kick his A$$... Not doubt ! [8D]
Old Dec 13, 2007 | 06:42 PM
  #39
bob12312357's Avatar
ORIGINAL: redsapphire89
yea mr black ur correct u can downshift w/o it but it isnt good i just up shift w/o the clutch
You can do it both ways without ruining the tranny. On that note upshifting is much easier to time right and theres gonna be less stress on the drivetrain if something goes wrong as opposed to downshifting. I use the clutch for 1-2 as its a longer throw and downshifts. You would be surprised how much time is lost using the clutch upshifting when a clutchless shift would have been a better option, this is really noticable on a track like VIR where on a 600 you shift often coming out of corners,the other bikes of the same kind as yours pull away and fast in the split second your clutch is slippin. To brake and downshift from 160mph on the back straight of the North course into the tight 45 mph turn at the end of it i use the clutch for obvious reasons. On the street in the upper gears no clutch for downshifts, just unload the tranny and theres 0 wear and tear. With cars, yes you can shift with no clutch. Just match the revs properly. You def shouldn't be able to go into a gear without the clutch with no grinding 3k revs 2 low for the gear.
xb6boix
Nov 9, 2012 02:39 PM
manufan
Sep 22, 2008 02:33 AM
jsgrabo
May 19, 2008 03:23 PM
erkmeoff22
Aug 20, 2007 08:15 PM
a4r6
Mar 27, 2007 10:27 PM
