coilovers/ shocks
Old Apr 26, 2007 | 07:21 PM
rambo82i's Avatar
Default coilovers/ shocks
Hi,
I have a set of coilover/ shocks that the pervious owner left me. They are made in germany and fits perfect for the TT but whats the benefit for putting them on?
Would it be easier to lower the car?
Old Apr 26, 2007 | 11:06 PM
cincyTT's Avatar
I'm make believe
Default RE: coilovers/ shocks
lower your car to however you like it and a firmer ride.
Old Apr 27, 2007 | 04:27 PM
ttoo cool's Avatar
From an engineering standpoint coilovers offer several advantage. Sure they lower the center of gravity and are a bit firmer but what does that mean?
Answer; A lower center of gravity will reduce roll (movement of the lateral axis about the longitudinal) as the lateral axis has been lowered and therefore will be more stable. A car is not an airplane and therefore movement about the vertical axis(yaw which is controlled by the steering wheel) is the only one desired as you can not travel up and down. Roll causes a loss of tire grip when cornering.
Second coilovers with well matched shocks allow a firmer ride without undue harshness. Audis are actually known for having the stiffest springs in the business (2-3X that of most makes) but ride quite smooth. A stiffer spring will also help reduce roll by allowing the chassis to move less freely. Once agin lateral stability is increased. Since they are adjustable the user can alter the settings to control everything from the stiffness of the ride to the dampening characteristics to increase or decrease stability in the front or the rear to adjust handling characteristics.
Happy Motoring,
TToo Cool
viperpit07
Mar 17, 2012 03:31 PM
@udikid
Feb 4, 2009 10:58 PM
twenty8red
Jul 20, 2007 02:16 AM
Sp33d07
Jun 2, 2006 01:39 PM
phroztbyt3
Aug 4, 2005 08:14 PM
