Common boost leaks
Old Mar 7, 2008 | 03:31 PM
Mac_17's Avatar
Default Common boost leaks
So I got a boost leak somewhere and my mechanic is getting tired of my car sitting at his shop. Any common boost leaks happen. I am thinking about just going through and replaceing most of the hoses if there badly damaged.
Old Mar 7, 2008 | 03:40 PM
ouTTie914's Avatar
Default RE: Common boost leaks
Do you have $15?
Old Mar 7, 2008 | 03:41 PM
Red_sapphire89's Avatar
hes a pos mechanic if he cant find the leak
ORIGINAL: ouTTie914
Do you have $15?
you need a compressor for that tool
Old Mar 7, 2008 | 03:49 PM
Mac_17's Avatar
Nah, just super busy. Guys has a three week waiting list but I ran mine over earlier this week. I like the leek tester.
Jason
Old Mar 7, 2008 | 03:50 PM
turbo kraut's Avatar
Tech Guru
Old Mar 7, 2008 | 04:04 PM
ouTTie914's Avatar
ORIGINAL: Red_sapphire89
ORIGINAL: ouTTie914
Do you have $15?
Yeah what's your point?
Most gas stations offer free air if you don't have a compressor, or access to one.
You may need a different fitting if you go the gas station route, but nonetheless it can be done.
Old Mar 7, 2008 | 04:37 PM
themysteryman83's Avatar
ORIGINAL: ouTTie914
ORIGINAL: ouTTie914
Do you have $15?
go to autozone and pick up some wheel stems for $3. that way you can use a bicycle pump if you want, lol.
Old Mar 9, 2008 | 09:44 PM
chosos's Avatar
Here is the pressure tester I made. Its a PVC reducer with a end cap. I drilled / Tapped the end and then I got an air compressor gauge / on/off valve setup from lowes for like 4 bucks. This doesnt give me a TON of flexibility for testing at specific PSI, but its close enough.
bigern45
Jun 8, 2015 11:59 PM
outti-a4wd
Jan 16, 2011 05:22 PM
Bklynrx7
Mar 25, 2009 08:20 AM
BrittAudi96
Jan 6, 2009 06:56 PM
koop
Mar 12, 2008 11:24 PM
