constantly running lean
Old Aug 20, 2007 | 09:53 PM
foxrcng11's Avatar
Default constantly running lean
every 3 days my car will go into limp mode and i get a check engine light... everytime its a running too lean. What would be causing that? Its an 01 180q everything is stock ran with 007 getting it... same thing with a forge splitter but when i run full bov i dont get it bc everything is being vented.... help plz its beyond annoying lol
Old Aug 20, 2007 | 11:06 PM
theTTkid's Avatar
Default RE: constantly running lean
maybe you should get a 4bar fpr... i think that helps but im not sure, im not great on running lean and in limp mode
Old Aug 21, 2007 | 12:14 AM
arturttq's Avatar
You need new MAF .....
Old Aug 21, 2007 | 01:48 AM
foxrcng11's Avatar
this is already my second one lol
Old Aug 21, 2007 | 11:36 AM
cincyTT's Avatar
I'm make believe
Go and get scanned. You could have a few things causing that. It be better to fix the correct one instead of guessing.
Old Aug 21, 2007 | 01:34 PM
foxrcng11's Avatar
when i run vag thats the only code that pops up... i disconnected the maf for a couple days and the lean code didnt come back but i got the running rich and low maf signal code which would beexpected but no lean code so that would mean thats the problem then huh?
Old Aug 21, 2007 | 02:55 PM
cincyTT's Avatar
I'm make believe
It is possibly a bad maf but if you get the exact codes number you can find out easy
Old Aug 21, 2007 | 04:19 PM
foxrcng11's Avatar
ive a lost of the codes on my laptop at home ill post it when i get home
Vezon
Dec 27, 2012 04:39 PM
vtraudt
Nov 2, 2012 09:50 AM
IronCobra53
Dec 2, 2011 03:44 PM
sixfiveoh
Mar 1, 2008 05:40 PM
brent78
Nov 19, 2006 05:50 PM
