Cooling Fan(s) not working, help please
sits as well...... explains more better LOL
L8R...... WE need a bouncing/dancing banana........
Yes! The battery sits on a plate/shelve, I understand.
I also am looking to replace the fuse box/plate that sits atop the battery?
Do you have the part number for that? I have a parts catalog and tat part is not listed?
You posted a picture of it, I want to replace that!
Ok! i changed the fuse tray atop the battery,I changed the fan switch and I have the control unit module....I ran the car to temp and I had to help the fan to spin, I'm thinking its the fan...anyone know where I can get one new or used? In Palm Beach or Broward,FL
VWpart#1J0959455D,F,A
Audi part# 6X0959455F
Anyone
call me
561-662-2454
coachv
Anyone
call me
561-662-2454
coachv
my turn signals stopped working, they work but not on there own. i can do the lever and they work and all works ok when i push the flashers. all works but when i use the lever l or r they just light and won't flash. i've checked the fuses in the car and all is good. is there a relay or another fuse that could be the problem? i am new to the site and i was reading some of the posts and was very impressed. thanks for your help
might check the fuses again ... and typically the hazard runs the right turn signal and the left I am unsure as I am brain farting right now
and if the flashers are not flashing and it does control at least the right hand blinker then the flasher unit is bad...
take it out and see if the connectors are bad/clean them that might be all they need
thanks NorthD,
i found the fuses that are on top of the battery and one 30a was bad
i replaced it and fans run and the air conditioning is working fine.
thanks for the help and other posts on this subject also helped.
fuses at end of dash drivers side will list which is what on panel you pull off of
end
