Cooling Fan(s) not working, help please
Old Aug 13, 2010 | 12:17 AM
NorthD's Avatar
Default aux fan controller
Originally Posted by coachvtt
Ok! Yes, the control module will be easier to change out than the larger fan.
I will prob change the fan as well, since its 9yrs old.
good thing for this forum, I did not know of the Control Unit Module!
Learn something new everyday about my TT..
have someone help you your girlfriend/wife you under the car and the other person putting bolts from above through holes you will see what I mean once you take the battery all the way off....... The bottom piece of where the battery
sits as well...... explains more better LOL
L8R...... WE need a bouncing/dancing banana........
Old Aug 13, 2010 | 10:28 AM
coachvtt's Avatar
Yes! The battery sits on a plate/shelve, I understand.
I also am looking to replace the fuse box/plate that sits atop the battery?
Do you have the part number for that? I have a parts catalog and tat part is not listed?
You posted a picture of it, I want to replace that!
Old Aug 13, 2010 | 02:49 PM
coachvtt's Avatar
Ok! i changed the fuse tray atop the battery,I changed the fan switch and I have the control unit module....I ran the car to temp and I had to help the fan to spin, I'm thinking its the fan...anyone know where I can get one new or used? In Palm Beach or Broward,FL
VWpart#1J0959455D,F,A
Audi part# 6X0959455F
Anyone
call me
561-662-2454
coachv
Old Jul 20, 2014 | 08:03 AM
gnibs's Avatar
Default turn signals not working
my turn signals stopped working, they work but not on there own. i can do the lever and they work and all works ok when i push the flashers. all works but when i use the lever l or r they just light and won't flash. i've checked the fuses in the car and all is good. is there a relay or another fuse that could be the problem? i am new to the site and i was reading some of the posts and was very impressed. thanks for your help
Old Jul 21, 2014 | 08:02 AM
NorthD's Avatar
Default Cooling Fan(s) not working, help please
might check the fuses again ... and typically the hazard runs the right turn signal and the left I am unsure as I am brain farting right now
and if the flashers are not flashing and it does control at least the right hand blinker then the flasher unit is bad...
take it out and see if the connectors are bad/clean them that might be all they need
Old Jul 23, 2014 | 10:57 AM
gnibs's Avatar
Default cooling fans
thanks NorthD,
i found the fuses that are on top of the battery and one 30a was bad
i replaced it and fans run and the air conditioning is working fine.
thanks for the help and other posts on this subject also helped.
Old Jul 23, 2014 | 11:02 AM
gnibs's Avatar
Default flasher relay
looking for the turn signal relay and or fuse locations.
turn signals all work but will not flash on thier own.
thanks gnibs
Old Jul 23, 2014 | 01:39 PM
  #18
NorthD's Avatar
thanks gnibs
the hazard switch in middle of 5 on dash is known to go bad
fuses at end of dash drivers side will list which is what on panel you pull off of
end
Old Oct 22, 2014 | 11:50 AM
  #19
dkmorley's Avatar
Default Need help replacing 01 TT cooling fans
Hi,
I have an 01 TT convertible. I need to replace the cooling fans. I'm looking for how to information. A video would be ideal but even a list of steps would be helpful.
Thanks
Old Oct 24, 2014 | 08:10 AM
  #20
NorthD's Avatar
Default DIY cooling fan Sorry no video/pic's
VWVortex.com - DIY: Cooling Fan Replacement
