Cooling fans are not working tried a few things now what?
Old Apr 8, 2007 | 11:28 PM
carguytt987's Avatar
Default Cooling fans are not working tried a few things now what?
Well the fans are definatly not working. even w/ ac on. They will start up for about 1 second then shut off i get to 107 C on the HVAC control readout on 49 &51. I checked the fuses on the top of the battery. they are all good no corrosion i even switched a couple nothing. what controls the fan. I Actuall have the blue top sensor, can i use the green one? I noticed ECS shows a blue and green one are they interchangeable? is this the only things that controls the fans? is there a relay ? where is it thanks Wayne
Old Apr 9, 2007 | 12:02 AM
diehlryan's Avatar
Default RE: Cooling fans are not working tried a few things now what?
there is a fan control module that could be shot.. i remember reading on audiworld in which a few people had to replace this. could be it, maybe?!
Old Apr 9, 2007 | 12:14 AM
you know how to test it? where is it located?
Old Apr 9, 2007 | 02:06 AM
looked some more, do we all have a after-run pump? i read somewhere it stays on for 10 min after we shut our cars off, I cannot find one where is it? i jacked up car and looked and turned on car and shut it off nothing? does this have anything to do with my fans not running? i did see the fan switch on the radiator, can i test for power or anything there?
Old Apr 9, 2007 | 02:14 AM
nevermind i found it on audiworld, I do NOT have the afrter-run pump.
ejl10
Jul 30, 2013 01:30 PM
OWDEE A3
Aug 10, 2011 11:08 AM
dafowler88
Jul 8, 2011 09:03 AM
ssbike
Aug 4, 2008 10:19 PM
tiffanys68
Jul 28, 2006 02:33 PM
