DIY - N249 Delete
Old Sep 28, 2008 | 01:07 PM
l88m22vette's Avatar
Default DIY - N249 Delete
http://forums.vwvortex.com/zerothread?id=4048354
Just wrote this up and wanted to post it for anyone interested
Old Sep 28, 2008 | 01:36 PM
theTTkid's Avatar
good work, i have a cel for the 249, so ill investigate this one haha
Old Sep 29, 2008 | 12:15 AM
01TT225Q's Avatar
what advantage/benefit is there?
Old Sep 29, 2008 | 01:03 AM
cincyTT's Avatar
I'm make believe
The resistor will get rid of one code, but you need a code in your chip to get rid of the other code if im not mistaken.
The n249 is like a backup to control boost. The ecu can use it to open the dv and lower boost pressure. If you remove it, you will have a smoother running car since the dv will be 100% closed. Of course it recommended that you use good boost control when doing this.
Old Sep 29, 2008 | 01:20 AM
theTTkid's Avatar
thats probably why i have the code seeing as i have no dv...
Old Sep 29, 2008 | 03:21 AM
TurboTT920's Avatar
more details plz... did you do this delete as well?
Old Sep 29, 2008 | 11:30 AM
MeanAudiA6's Avatar
i followed the vortex one but as its for a 180 model i had to figure most of it out by myself which wasnt too hard....good to see one for the 225....now u need to do the EGR block off plate and remove the SAI pump
Old Sep 29, 2008 | 02:54 PM
TurboTT920's Avatar
I have an extra block off plate if anyone needs one, still in the package.
they're $40 new from 20squared
Old Sep 29, 2008 | 04:47 PM
Wintermute's Avatar
Is that something that a vagcom can handle or revo/apr/uni?
Old Sep 29, 2008 | 05:15 PM
cincyTT's Avatar
I'm make believe
I know uni has the files for it, not sure about revo or gaic, but i do know APR doesnt have it
