Drive after DP install
Old Oct 11, 2008 | 09:04 PM
keefboz's Avatar
Default Drive after DP install
Drove my car today for the first time since the DP got installed, felt great. Much better response, boost seemed to spool quicker aswell.
However, my exhaust was not put back properly and hangs lower than it did, i also have a small leak somewhere... looks like tranny fluid....
On the whole though very happy with the gain
Old Oct 11, 2008 | 09:13 PM
achTTung's Avatar
Hangs lower how? Cant really change exhaust hanger height, unless you didn't clamp the front and rear sections of exhaust tight enough, and its hanging a bit in the middle (under the seats just about)?
Old Oct 11, 2008 | 09:18 PM
jojoenglish85's Avatar
ya i know what you mean, it felt great after installing my full exhaust, 3" from dp back, have fun, not you need to upgrade that turbo.
Old Oct 12, 2008 | 12:39 PM
keefboz's Avatar
as in the tip is not flushed with the valance like it was! it hangs lower! just looks a bit unprofessional
Old Oct 12, 2008 | 05:31 PM
drsmith's Avatar
Cool, was it worth it then?...
It may just need a slight adjustment on the bushes or it could not be lined up 100% perfect on the join, have a look underneath and see if you can rotate it
Old Oct 12, 2008 | 07:28 PM
cincyTT's Avatar
I'm make believe
dp's make a noticable gain, so thats always worth it.
And i have to agree with the above, if they didnt align the hangers in the bushings right, it can hang lower or just be off. Just jack up the car and redo it yourself, its not like you have to undo anything
Old Oct 13, 2008 | 09:48 AM
keefboz's Avatar
I emailed the people that did it and they said they are happy to adjust it for me, which they should be!
The gains are so worth the 275 dollars i paid for the install and the DP, i really didnt expect them to be THAT noticable, it was as noticable as the chip was.
Old Oct 15, 2008 | 04:46 AM
jason bouchard's Avatar
if only it was this cheap for a 225 dp. good mod though
Old Oct 15, 2008 | 07:42 PM
keefboz's Avatar
got the tip re positioned and there is no problem with the tranny fluid. did get a cell that said somethin was wrong with my cat, if it happens again they are going to replace it!
Is this normal for a DP to throw this code?
Old Oct 15, 2008 | 07:46 PM
hmm that maybe my problem lol... i did the full exhaust im gonna get a spacer and find out if it still does it.
kbevere
Oct 14, 2010 09:36 AM
1BADS4
Feb 21, 2007 10:51 PM
sandnsnow24
Feb 15, 2006 02:26 AM
CaliA4
Sep 5, 2005 01:21 AM
