DV Dumping
Old Sep 29, 2007 | 10:51 AM
Indiepunk's Avatar
Default DV Dumping
It has been less than a week since I got my car running properly and now the DV is acting up. Before it only dumped when I released the gas to shift. Now it does it when it hits 15psi or a couple times in succession in the lower gears. Can anyone shed some light on possible causes? Springs?
Old Sep 29, 2007 | 10:52 AM
MeanAudiA6's Avatar
Default RE: DV Dumping
what setup u got in the dv now?
Old Sep 29, 2007 | 10:54 AM
neur0tic's Avatar
.... ditto.... what springs/shims do you have in it?
Sounds like the fluttering caused by wrong DV tuning.
Old Sep 29, 2007 | 10:56 AM
theTTkid's Avatar
or maybe just a loose connectiong? or possible break in hose if not the DV
Old Sep 29, 2007 | 01:31 PM
Indiepunk's Avatar
ORIGINAL: theTTkid
theTTkid gets it right. I blew another hose. The TT is up and running yet again. Hopefully I can go another week without something else failing.
Old Sep 29, 2007 | 03:30 PM
twenty8red's Avatar
what would be the correct spring/shim combo in a 007 dv for a 180q with a apr 93 flash?
thanks
Old Sep 29, 2007 | 03:36 PM
MeanAudiA6's Avatar
not sure i use yellow spring with one shim
Old Sep 29, 2007 | 05:34 PM
Murderface's Avatar
I think I can answer this from memory from how much it's asked.
green=stock PSI
yellow=15-18 PSI
blue=18-24 PSI
Old Sep 29, 2007 | 06:21 PM
cincyTT's Avatar
I'm make believe
What about the read one? [8D]
Old Sep 29, 2007 | 06:27 PM
theTTkid's Avatar
im always rightjk
IAmRain
Aug 5, 2015 07:45 AM
andrewzpsu
Nov 29, 2010 12:52 PM
The Bishop
Mar 22, 2007 10:04 AM
