ECS Stage 1 Clutch ordered
Old Jan 25, 2007 | 08:33 PM
diehlryan's Avatar
Default ECS Stage 1 Clutch ordered
Ordered my Stage 1 Clutch today from ECS.
Can't wait to get it in.
However the invoice was sent to me in a PDF format as the bill to name JASON and not RYAN. No idea how that was interpreted but I know I didn't put it in wrong when ordering.
Hope it still makes it.
Old Jan 26, 2007 | 02:35 AM
MeanAudiA6's Avatar
Default RE: ECS Stage 1 Clutch ordered
how much did it run ya? i couldnt find it on the website. did u get a new FW?
Old Jan 26, 2007 | 07:30 AM
225tt's Avatar
How much TQ is it rated to hold, I found that it seemed a little to expensive for my taste so I went with SPEC like MeanAudi, but hey to each his own.
Old Jan 26, 2007 | 11:49 AM
diehlryan's Avatar
$349 with free shipping.
Here is the description on the website:
This is our #1 selling clutch kit. MostMk4 4 cylinder carswill damage the stock dual mass flywheel when the clutch starts slipping. The dual mass flywheel when bought from V/W is over $500. We offer the complete kit that includes a OEM lightweight 14 steel flywheel for less than just a flywheel from V/W. This kit will retain stock like pedal characteristics along with much improved clamping force & larger diameter clutch assembly. Lighter OEM Steel flywheel only 14lbs versus 22 lbs of the stock 1.8T. This is not a lightened modified OEM flywheel like others.[*]20-30% more clamping force than stock clutch![*]Faster spool-ups & more horsepower![*]Kit uses OEM Sachs VR6 Clutch pieces[*]Kit is good up to 200-250 wheel Horsepower & up to approx 275lbs of wheel torque[*]Excellent pedal feel pedal retains OEM type feel. Kit includes the following parts:[*]Lightweight steel OEM flywheel[*]Sachs clutch pressure plate[*]Sachs clutch disc[*]Sach's OEM throw out bearing[*]OEM throw out bearing[*]OEM flywheel bolts Installation: Torque Flywheel to crank 60Nm.(44ft.lbs.) + 1/4" turn (90deg)Torque Pressure Plate to Flywheel 20Nm.[/align]
Old May 2, 2007 | 11:26 PM
ooantipostoo's Avatar
Hey does any one know if this will fit a 2000 TT 1.8t FWD? If not what would be the best offer for a clutch and flywheel?
Thanks,
Ryan
Old May 2, 2007 | 11:41 PM
diehlryan's Avatar
Man you dug up an old thread.
It should fit no problem.
After a few months of driving my impressions are nothing but good. Others really hype SPEC though so look into that as well.
Old May 3, 2007 | 12:24 PM
bmwtoaudi's Avatar
I have this clutch installed on my 2000 FWD TT. - Its pretty sweet. - It holds much better than the stock TT. - The clutch peddle itself will feel considerably lighter than the stock version. (Note its common, and extremely scary at first) - Anywho ..it is worth the buy... however you will notice more tranny noise in your car because of the lighter flywheel. - but its hard to notice.
I wouldn't take the purchase back, Also depending on if you need it or not i'd suggest you replace the starter at the same time. - its right there and you can get them on ebay for around $100. - Mine was starting to go, and it was a free install because its right there when they are removing the clutch/flywheel.
just food for thought!
~Chris
Simon0605
Jul 19, 2008 03:51 AM
Red_sapphire89
Feb 23, 2008 01:34 AM
irish222222
Feb 3, 2006 08:32 PM
