Engine check light on!!!
Old Jan 17, 2008 | 09:39 AM
hwang8's Avatar
Default Engine check light on!!!
I just had the engine check light on yesterday on my TT!
I had the dealer check it out, and they said it was because of the O2 sensor and the catalyst. I think it's not a big problem, but it just bothers me to see a yellow light that says ENGINE CHECK.
For those of you who replaced the intake, or exhaust, did you have the engine check light turn on?
Old Jan 17, 2008 | 09:46 AM
WishIWasRWD's Avatar
Default RE: Engine check light on!!!
It's not just common, it's expected.
Old Jan 17, 2008 | 10:34 AM
beachchair's Avatar
Mine is on so often, I would think something was wrong if my CEL was off. I'm ready to get into the instrument cluster and "modify" the light.
Old Jan 17, 2008 | 11:02 AM
cmh's Avatar
cmh
If you have modified the DP or exhaust in any way the CEL is expected. Common fix is to space the o2 sensor out from the exhaust stream with a spacer block and then reset the CEL. This will trick the o2 sensor/ecu into reading normal levels and then no cel's will be thrown.
Old Jan 17, 2008 | 12:42 PM
bmwtoaudi's Avatar
Mines been on for 6 months because of the CEL - I just dont care anymore.
As noted, I'm going to modify my cluster this spring and remove the light bulb
Old Jan 17, 2008 | 12:59 PM
MeanAudiA6's Avatar
good luck with that^
Old Jan 17, 2008 | 05:35 PM
bmwtoaudi's Avatar
- Did it in my first BMW. - Worked like a charm.
Old Jan 17, 2008 | 05:47 PM
And Ichanged the cluster lights in my oldcivic to green...
I hope it's just as simple for you.
With how finicky the electrical is in the TT, I wish you luck sir.
Old Jan 17, 2008 | 05:54 PM
jakej's Avatar
I did it before too... Don't just remove the light, put a low ohm resistor in it's place. It'll be exactly the same then, minus the lighting.
If I didn't put the resistor in when I did it to my last car, my cruse didnt work for some reason.
This is coming from a electrical engineer.
jakej's Avatar
Now that I think about it, it was the abs light. Thats why the cruse didnt work.
