Exhaust Problem
I was driving today and i heard a nice pop. I didnt no what it was i took it to a guy i no at a shop he said my flew pipe broke. thats the Dp right? they want 230 to fix it. u think i should jsut spend an other 20 or 300 and get a exhaust or just fix it. i found this on ebay it is good enough?
http://cgi.ebay.com/ebaymotors/99-04...QQcmdZViewItem
Thats made to fit the stock exhaust. You can either just cut the correct step down and insert a pipe or go to 42dd and get a cat with the correct size fitting or their tp also.
No, they had fwd dp's also
This is the parts im refering to
[align=center]
[/align]
[/align][align=center][/align][align=center]with the correct[/align][align=center][/align][align=center]
[/align][align=center][/align][align=center][/align]
[align=center]
[/align]or
[align=center]
Cause you probably need to go to the MKIV stuff
http://42draftdesigns.com/categories...8tdownpipe.htm
The difference between the cat and race is $75. It should be around $100 for the cat and end peice. But if you dont need a cat, i would just cut the ebay dp at either 3" or 2.5" to match up with the new catback and just add a pipe and o2 bung and another exhaust sleeve. Be a little cheaper.
http://42draftdesigns.com/categories...8tdownpipe.htmThe difference between the cat and race is $75. It should be around $100 for the cat and end peice. But if you dont need a cat, i would just cut the ebay dp at either 3" or 2.5" to match up with the new catback and just add a pipe and o2 bung and another exhaust sleeve. Be a little cheaper.
