few issues
Old Nov 30, 2008 | 03:09 PM
AWDrifter's Avatar
Default few issues
About 2 days ago I noticed the car does not beep when i hit "lock" with the remote like it used to. Didnt think much of it because it still looks, just doesnt beep.
Today I noticed my window didnt drop the 1/4 inch or so when I opened the door. And tried and my windows dont go up or down at all. Could this be a blown fuse or something?
Think these are 2 unrelated issues?
TIA
Old Nov 30, 2008 | 03:29 PM
XCLR8TT's Avatar
It could be a fuse ... layout here Check #5, #10 and #15 for starters. The window 1/4" drop may be related to this as well, but just in case take a look a this post as well. Windows won't drop
It would be a good time to use VAG-Com to check for codes as well, you could have an issue with the central locking module.
How good is your battery? Check that to make sure you are showing >12.5V at rest.
Old Nov 30, 2008 | 04:41 PM
AWDrifter's Avatar
I saw the other thread but figured this was different because the windows wont go up or down at all. I will check the fuses. I think the battery is fine but can check it with a multimeter. Everything else, radio etc. works fine.
Old Dec 1, 2008 | 07:40 PM
AWDrifter's Avatar
Ok so I am looking in my bentley manual and in the list of what each fuse is used for I dont see anything for windows. Am I blind? I dont think 5, 10 or 15 per the previous post are what I am looking for because I dont have a 2001 and neither the explaination in that link or the bentley make those look like the culpret. Any suggestions?
Old Dec 2, 2008 | 12:47 PM
theTTkid's Avatar
there is a fuse for your horns somewhere... im not sure if they are the same though, meaning the horns from when you honk to the horn when you lock
tofast2belast
Sep 19, 2012 06:08 PM
ImTheDevil
Aug 3, 2011 09:11 PM
awk81
Jan 10, 2007 02:56 PM
rfors777
Jun 17, 2006 12:26 AM
kenestle
Dec 4, 2004 08:31 PM
