gaping wound in breather hose....
Old Apr 22, 2008 | 09:53 PM
twenty8red's Avatar
Default gaping wound in breather hose....
my three way breather hose that sits on top of the valve cover has a hole in it about the size of a quarter. it doesn't look like a tear or rip but more like it was melted through with the tip of a fat cigar. does anyone know if this is a common occurrence or something i should be worried about.
this hose:
[IMG]local://upfiles/29352/2FAFB6DC71D84CE48262170B5B375E6F.jpg[/IMG]
Old Apr 22, 2008 | 10:16 PM
theTTkid's Avatar
Default RE: gaping wound in breather hose....
i got a big hole in mine too... right in the bend going into the valve cover. doesnt seem to be an issue
Old Apr 22, 2008 | 11:41 PM
cincyTT's Avatar
I'm make believe
its part of your pcv system. If you dont fix it, you will have oil all over your engine bay and soon lose performance. The best alternative i have seen is using the hardpipe that comes in a ATC and AWD (both 2000 cars) instead.
Old Apr 23, 2008 | 07:52 AM
theTTkid's Avatar
...crap haha, sucks that the OEM hose is like 70 bucks
Old Apr 23, 2008 | 08:21 AM
theTTkid's Avatar
ok so i have been thinking... mine has a hole as well... not huge but its a good size, think i could just use some heat tape on it? at least as a temporary fix?
Old Apr 23, 2008 | 08:34 AM
diehlryan's Avatar
http://www.20squared.com/catalog/pro...6eefadd48db21f
Old Apr 23, 2008 | 09:12 AM
beachchair's Avatar
Recently had to replace a hose in that SAI cluster due to a large hole. Hose cost $56.00. All the more reason to eliminate that whole mess.
Old Apr 23, 2008 | 10:14 AM
twenty8red's Avatar
cool. thanks. i think i'll go ahead and get that eurojet one.
Old Apr 23, 2008 | 11:31 AM
theTTkid's Avatar
does the eurojet one fit both 180s and 225s?
Old Apr 23, 2008 | 02:28 PM
cincyTT's Avatar
I'm make believe
180's with AWP engines
SSEI173
May 25, 2014 04:31 PM
bmob222
Aug 30, 2013 03:05 AM
divil
Oct 11, 2009 07:10 PM
bontyal
Feb 23, 2006 04:03 PM
