gauges Gone Insano
If you have a VAG COM, go to module 17 (dash panel insert) and then go to output diagnostics i think, and do a gauge sweep. The gauges will go all the way from the left to the right, then they will all point straight upwards... If all of the gauges work correctly, then its not an instrument cluster problem which is common on the TT.
