Got a potential problem
Old May 17, 2008 | 10:51 PM
TheBlackPearl's Avatar
Default Got a potential problem
So yesterday I was driving and everything was fine
then after about 30min of driving around town I noticed something
Its summer and my exhaust was putting out a good amount of white smoke everytime i accelerated from a stop
and my temp gauge was running just a smig too hot like one bar over half way
I checked the radiator fluid and it was at a decent level and everything else looked fine
any suggestions as to whats going on?
cause I cant figure it out and thats not normal
so I want to get it fixed before its a real problem
Old May 17, 2008 | 11:02 PM
exTTreme's Avatar
Default RE: Got a potential problem
I did a search for you and from reading the results I learned it could be your temp sender
Old May 18, 2008 | 02:04 AM
My temp sender?
the Thermostat ?
or a sensor ?
Old May 18, 2008 | 08:10 AM
beachchair's Avatar
Bad temp sensor is not going to cause smoke. Worst case, white smoke is caused by water in the exhaust. Do you smell any coolant while the engine is running?
Old May 18, 2008 | 09:52 AM
exTTreme's Avatar
My bad I was saying temp sender for the gauge reading one bar over half
pure white smoke/steam is coolant and will have a sweet smell
In my case the offwhite/grayish smoke that I had was from oil burning and it smelled like burning oil (at a loss for what else I could use to describe the smell) when I pulled off my old intercoolers/piping I found oil all the way from the charge pipe to the throttle body I cleaned the hoses out before reinstalling them and then drove 50 miles to test out my new FMIC and the smoke that I used to see all the time is now gone and so far there is no oil in the piping.
Since you said your coolant is not low maybe pull the hose off your throttle body and look for oil
Old May 18, 2008 | 10:34 AM
cincyTT's Avatar
I'm make believe
white smoke = coolent
blueish smoke = oil
It honestly sounds like the turbo seals might be going out.
johnson90512
Aug 7, 2024 01:57 PM
quattroholic23
Jan 29, 2012 03:44 AM
theTTkid
Mar 31, 2008 12:32 AM
a42point8awd
Sep 10, 2007 10:19 PM
orangetravelcat
Mar 17, 2007 05:42 PM
