Grill
Old Dec 4, 2008 | 04:06 PM
jhsoccerodp's Avatar
Default Grill
Any Diys for grill removal? I searched but cant locate one. Is it simple or do you have to remove the bumper?
Old Dec 4, 2008 | 04:13 PM
keg225's Avatar
You have to remove the bumper if you want to save the grill. If you are replacing the grill and do not care about the stock one, just cut it apart and remove it, then just pop the new one in place. I changed to a badgless one in about 20 minutes.
Old Dec 4, 2008 | 07:33 PM
myslow1's Avatar
if you dont care about your oem grill here is a diy
1) place hands on bottom of grill
2) pull
3) place hands towards top if grill
4) pull
5) install new grill
Old Dec 4, 2008 | 07:58 PM
AWDrifter's Avatar
the first 4 steps are much more descriptive then the 5th
Old Dec 4, 2008 | 08:17 PM
achTTung's Avatar
I had to take my bumper off to install my FK grille. I just couldn't quite get the tabs to latch in place w/o some serious pressure that would have just caved my bumper in if I couldn't press from the back side as well. Also, I wasn't about to try unbolting only the top of the bumper and sticking my arms in there. That **** gets old when you're screwing with something you can't quite see, and its scratching up your arms as you try.
If you need directions for removing the bumper, most screws are pretty easy, 4 nuts are hard to see/get to. 2 on each side, access from the wheel well. Basically, bumper has 2 studs to pull it in tight to the body on either side. Pull those nuts (and the rest of the screws across the top/bottom of the bumper) and then pull the whole thing forward. It'll probably fight you a little bit, but some elbow grease fixes that.
Old Dec 4, 2008 | 08:53 PM
warranty225cpe's Avatar
^and where do you find this "elbow grease"? and is it expensive? lol
Old Dec 4, 2008 | 09:08 PM
myslow1's Avatar
hahaha
Old Dec 4, 2008 | 09:29 PM
achTTung's Avatar
Kaleco actually, its listed right below the blinker fluid.
yeah, for real. http://kalecoauto.com/index.php?main_page=index&cPath=2
trill
Nov 8, 2011 10:15 PM
samleong
Nov 28, 2009 02:41 PM
2kaudi
Oct 31, 2007 06:30 PM
CrazyBignate
Dec 14, 2005 10:23 PM
