Group Buy Water/meth
ORIGINAL: cincyTT
The black one, wire 5 for the maf
Purple and grey for map
I had that confirmed by Chance of Devil's Own. I sent him the wiring diagram for my Bentley CD.
Here are some more pics. Almost done.
Pump Mounted
Mounting Screws Coming Through
Mounting Screws Trimmed
Water Feed Line into Washer Tank. (Instead of using the tap that came with the kit, I just drilled a 1/4" hole in the top of the tank and ran the water line down to the bottom.)
Nozzle installed with Throttle Flange
Water Line to the Nozzle
MAP Connector. (The Purple/Gray wire is in position 4; all the way to the right.)
Back together
Up close
Next: Hooking up the controller and I done!
I'm done and took her for a test drive. I really feel the pull under full boost in higher gears. I want to adjust the timing but I recently upgraded my VAG-COM cable from serial to USB. But my Lemmiwinks program is looking for a serial port (I think). How do you use it with USB?
I also have APRTune, but it doesn't seem to let me change values. Does it only work with APR software?
TIA
TIA
so you went with the D03 at the tb?> what do u run after intercooler? your dual nozzle correct? i was gonna go either D01 or D02 at the TB and a D04 after intercooler before the map sensor
