Group Buy Water/meth
Old Apr 20, 2008 | 01:36 PM
  #161
Mobius97's Avatar
Default RE: Group Buy Water/meth
ORIGINAL: JettaRedII
Short answer: your stuff is OK.
Thanks for the confirmation and explaining that to me!
Old Apr 20, 2008 | 01:37 PM
  #162
JettaRedII's Avatar
ORIGINAL: MeanAudiA6
idkl what it is but the fuel filter with that part number u posted is metal....and the barbs are way too big....is it in a blue box and says F20011??? lol thats crazy...i def want the clear one to see whats going on...
Hmmm, I'll check the filter itself. The box said F20011, but people have been known to swap stuff.
Old Apr 20, 2008 | 03:20 PM
  #163
Audi_Skydiver's Avatar
Ok, so I am really confused now. I disconnected the W/M kit and just tried starting the engine. I STILL get misfires in cylinders 2,3, and 6. It's consistant now and will not go away. I plugged the tubing going to the nozzles as well just so it was not sucking in any extra air or anything and it still does it. Whats the deal? Oh and my brakes don't work anymore ever since I have been getting the misfire problems. This is starting to make me mad. I did replace the spark plugs yesterday but I have done that a hundred times and never have had this problem. I put NGK BKR7E's in gapped to .028. I also have the GIAC-X ECU installed. Anyone have any ideas? Oh and I took the check valve apart again and it's fine. THere was NOTHING in there.
Josh
Old Apr 20, 2008 | 03:50 PM
  #164
MeanAudiA6's Avatar
how about you take some pics on where u have your nozzles....and also how fresh are your coilpacks?
Old Apr 20, 2008 | 04:02 PM
  #165
JettaRedII's Avatar
F20011 is what is printed on the filter, too.
Old Apr 20, 2008 | 04:08 PM
  #166
Pictures are uploading now.
As for the coilpacks I am not sure. I just got the car a little while ago. It has 76K miles on it.
Josh
Old Apr 20, 2008 | 04:15 PM
  #167
Pics:
Oh and the cylinders that are misfiring are 2,3, and 6. These cylinders are the ones farthest away from the TB. So IDK! [:@]
Josh
Old Apr 20, 2008 | 04:57 PM
  #168
JettaRedII's Avatar
I see what you mean by the check valve getting in backwards. The single kits have one end threaded.
The firing order is 1-4-3-6-2-5. If 3-6-2 are misfiring, you should really notice it. It still sounds like some kind of vacuum leak. Are you sure where you tapped and installed the nozles are completely sealed?
Old Apr 20, 2008 | 05:02 PM
  #169
I defenently know there is a misfire. It' idles insanely rough and sounds like crap. I know they are all sealed. I check them multiple times. But would a little extra air going into the intake cause 3 cylinders to misfire? I disconnected the WM kit so NO fluid was being injected (unplugged the hose going from the check valve to the Y splitter thing). Nothing changed. I could plug that hose going to the nozzles and nothing would change. I am thinking it might be something not related to the WM kit. I have no idea though.
Josh
Old Apr 20, 2008 | 05:15 PM
  #170
MeanAudiA6's Avatar
gosh i thought our engines were a bitch to work on...that thing must suck lol anyways...idk about anybody else but i cant clearly see where those nozzles are....if you took a shot of the engine bay further away and then photoshopped where they are...it would really help me....im not very familiar with the 2.7T but i can get a better idea...like in the very last pic what is that> to me it doesnt look like a TB ...where are you injecting?
