Group Buy Water/meth
ORIGINAL: Red_sapphire89
lol he needs a turbo inlet hose before he goes meth injected he doesnt like the collapsed hose feeling
If you want real info on wmi, see the BT and HP sticky. Its near the bottom
This code will give 20% off on all kit orders. bddb4b This coupon will be good for the next 9 days. If someone needs longer have them email me DevilsOwn of his contact us page to make arrangements. Everyone is going to want the 2.5 Bar kit. If you are wanting nozzles other than DO3 and DO5 please put in the notes and we will exchange for you. Dual nozzle guys probley will want the 2 and 5 or 2 and 4 and the signal nozzle guys if they are low modded will use the do3 and the higher hp guys will run the do5 Everyone will need the 2.5 bar controller. http://www.alcohol-injection.com/wat...tage-2-12.html dual nozzle upgrade http://www.alcohol-injection.com/upg...grade-200.html
After reading the description of the Stage 2 (Progressive) kit, I changed my order to that one. That truly does seem the best way to go. I initially wanted the Stage 1 because of my experience with Aquamist. My Aquamist kit is about 7 years old and had an older, piston-style pump. Aquamist's solution for progressive water injection was to use an expensive High Speed Valve (HSV) that was triggered by the fuel injector. I never saw an improvement in performance and didn't think Stage 2 was worth the extra bucks. However, talking to Chance and reading the description on Devil's Own website, I now understand it operates differently and I expect it to show marked improvement over the simple on/off method of Stage 1.
My question now is does anyone have a good recommended place for the pump?
I'm down to buy the dual kit I posted it in the a4forum and got no reply e-mail mewhen it's ondiverrhettnelson@yahoo.com
Thanks
Thanks
Just ordered my kit, nice about $90.00 off!! MeanAudi just wanted to say thanks for the hard work in setting this up, kudos!
Hopefully I ordered what I needed. I just go the stage 2 with the 2.5 controller, a 2qrt tank (don't know where it is gonna fit), float switch, dual nozzle kit and some w/m mix. I made a comment on the order asking to verify the nozzle size for my app. From your last post, MeanAudi, you stated get a 2 and 5 or 2 and 4. Youare talking about the part number's for the nozzlescorrect, as in D02 and D05?
