grrr issues with windows and tach
Old Jan 10, 2007 | 12:16 AM
foxrcng11's Avatar
Default grrr issues with windows and tach
so im having fun withmy car.... first my passenger windows stops working you can hear it clicking but it doesnt roll up or down... my maf is going out as well so it keeps throwing codes... i was changing my oil today and i disconnect the battery to reset the ecu and get rid of the check light when i put the battery back on the code was gone but now my driver window doesnt go down when i open the door and the auto up and down is gone.......
and on the way out to the place where i changed the oil my tach just stopped working... everything else on it works fine but the tach. it kinda stutters at the 0 rpm mark but for the most part it doesnt do anything.... What do I need to do? do i need a new cluster and what about the windows?
Help!!! lol [sm=headbang.gif]
Old Jan 10, 2007 | 12:36 AM
achTTung's Avatar
Default RE: grrr issues with windows and tach
window fix:
With the window down, raise the window all the way, then click the switch 'up' and hold for at least one second.
Window should be reset.
Old Jan 10, 2007 | 01:19 AM
cincyTT's Avatar
I'm make believe
if your maf is going out you can try running it with it unpluged. You wont get the codes but you will run a little rich. Also do a throttle body alighnment. To do it unplug your battery for 10min then reattach it, then go turn your car to the on position but not start it for another 10mins. Then start it and see if those two things help cure some of your problems.
i would still be in search of a new cluster though.
Old Jan 10, 2007 | 06:02 PM
foxrcng11's Avatar
cool thnx guys.... the window thing worked great so thats one issue down and a few more to go .....for the throttle alignment, what does that do exactly?does it reset things or something? im definently going to do that tonight after work but just curious on exactly what it does. for the tach is it hard to replace? im not in the mood to take it to audi and spend about a grand but i dont wanna get in over my head either lol.... i saw a diy on replacing the needles and the part that operates it but im not sure if thatll fix it
Old Jan 10, 2007 | 06:38 PM
cincyTT's Avatar
I'm make believe
your throttle body (tb) is run electronically. And since you disconnected the batterie and started it up it may not be where the ecu thinks it is. It is something that should be done a regular maintance or when you change somethings. If you have a vag cable you can do it electronically with a laptop but if not you have to do it like listed above.
Old Jan 10, 2007 | 10:34 PM
foxrcng11's Avatar
just curious but im looking around online and noone else that i can find has had their tach go out.... i see a lot for the fuel and temp but not the tach. has anyone had a tach go bad on here or that someone can find
Old Jan 10, 2007 | 10:39 PM
cincyTT's Avatar
I'm make believe
cound this on vortex you can try, wouldnt hurt. http://forums.vwvortex.com/zerothread?id=1678991
also you might wanna try inspecting the wires, they maybe eroding or something.
XCLR8TT's Avatar
Yes it happens. You can send it to BBA reman and have it fixed for $250.
jasko315
Mar 8, 2011 12:58 PM
edub18t
May 28, 2009 03:53 AM
dana3
Nov 17, 2008 12:01 PM
fuzz_duster
Apr 22, 2008 11:13 PM
fuzz_duster
Apr 21, 2008 04:07 AM
