Hardwiring Radar Detector
Old May 7, 2007 | 05:30 PM
Justin_72's Avatar
Default Hardwiring Radar Detector
Alright, time to hardwire in the radar detector just in case I ACCIDENTLY speed...haha! Anyway, I'm curious as to which power and ground points you've found under the steering wheel that are easily accessible and safe to use. Also, any helpful tips on removing the top dash, a-pillar, and lower-steering wheel panel would be appreciated. Thanks!
Post pics if you got em too!
Old May 7, 2007 | 05:58 PM
thak's Avatar
Default RE: Hardwiring Radar Detector
here is a great writeup for tapping power and ground for any install....
http://www.loomknitting.com/auditt/easyvalentine.html
Old May 7, 2007 | 07:06 PM
Justin_72's Avatar
Sweet deal - thanks!
Old May 7, 2007 | 09:00 PM
sheepcan's Avatar
I hardwired mine and didn't have to remove the pillar. I just stuck it behind it, you can't tell it's there I always have people comment on it.
Old May 8, 2007 | 08:45 PM
munkee's Avatar
i put mine in the middle of the dash (on top) in between the vents.
i ran the wire down the vent, behind the dash and actually wired it into the clutch relay.
Old May 8, 2007 | 08:58 PM
stephenson27's Avatar
Put mine in the same spot between the vents on the dash but tucked the wire down between the dash and windshield then to the fuse panel and tucked it behind the weather stripping. Stupid easy.
I actually ended up getting the windshield replaced not to shortly after installing it and they worked the wire even further down between the two.
robertmrome
Feb 15, 2008 03:43 AM
Swaynest
May 14, 2007 11:38 AM
dansaudi01
Jul 28, 2006 06:05 PM
auS4di
Mar 7, 2006 02:37 AM
