Headlamp/electrical problems....help!
Old Feb 12, 2012 | 08:57 PM
Motoxer310's Avatar
Default Headlamp/electrical problems....help!
I have an 02 audi tt quattro 225hp with a 6spd. I just purchased this vehicle and noticed the hid xenon low beam on the drivers side doesn't work. All the other lights in the headlamp works just not the low beam. Swapped it out with the other side that does work and still no light on the drivers side. Also On the passenger side the running light (amber) doesn't work...but that turn signal works. It's the same bulb, single filament. I obviously have an electrical problem. Took it to my mechanic that isn't an audi dealership and he tested everything he could and couldn't find anything wrong. But he couldn't test the BCM (body control module) and he thinks that might be the problem for everything. Oh and my cruise control doesn't work. Does this sound right?! Can it just be flashed? Rebuilt? Im just trying to avoid throwing a ton of money at the dealership....is it worth me buying a vag com or hex com to find out? Will it tell me electrical faults or if something is wrong with the bcm? sorry im just lost and new to audi :/. Any help would be greatly appreciated!!
Old Feb 13, 2012 | 03:54 PM
cincyTT's Avatar
I'm make believe
Have you checked all the fuses and wires yet?
Old Feb 13, 2012 | 06:17 PM
Motoxer310's Avatar
Yeah....I did and my mechanic went and double checked everything as well
Old Feb 13, 2012 | 09:10 PM
cincyTT's Avatar
I'm make believe
Could be a bad hid ballast and a bad relay on the turn signal. Cruise control could be the stalk. Have a place scan for codes to see if anything pops up
Old Feb 14, 2012 | 01:48 PM
Motoxer310's Avatar
Alright ill check into that thanks!
Mercy404
May 2, 2015 09:22 PM
Motoxer310
Feb 12, 2012 08:59 PM
srlito
Jan 19, 2009 06:40 PM
Trainwrek024
Jun 24, 2007 07:49 PM
AndyMelvin
Dec 8, 2005 02:35 PM
