Headlight Removal
Old May 14, 2008 | 07:37 AM
beachchair's Avatar
Default Headlight Removal
Anyone had any luck removing the headlights without removing the bumper cover?
Old May 14, 2008 | 08:24 AM
theTTkid's Avatar
Default RE: Headlight Removal
pretty sure you have to take the bumper off
Old May 14, 2008 | 08:44 AM
cmh's Avatar
cmh
I just pulled my bumper last weekend to seal my lights better and to test out some led's.
When I was putting it back together one of the headlights wasn't lined up very good and needed adjustment, but I had already put the bumper back and had some of the fasteners on, so I wondered the same thing, could I get to the bottom headlight bolt to loosen it enough without removing the bumper again?
Answer:
NO Impossible unless your arm is very skinny and has six elbows. If you could remove your grille from the front with out removing the bumper it might work, but the bottom headlight bolts are long, like 2.5 inches and I don't know how much clearance you would have to back them out.
I even thought about not using those bottom bolts and just letting the headlight hang from the top two but it was flimsy when I tried it, felt like the top tabs wouldn't last long
Old May 14, 2008 | 12:09 PM
beachchair's Avatar
Good explanation. I was afraid of that.
bronxblaza117
Jan 15, 2008 02:06 AM
kaptom540
Dec 29, 2007 01:01 PM
ocadam
Nov 23, 2007 08:06 AM
Gumby11
Aug 15, 2007 04:18 PM
nhltfour
Jun 18, 2006 04:11 PM
