HELP ASAP
Old Jul 26, 2006 | 01:51 AM
MeanAudiA6's Avatar
Default HELP ASAP
does anyone know how to take the wiper ares off? i'm trying to install my boost gauge and need to get the whole wiper arm set off please help asap if you know how. i undid the nuts and took the caps off but it looks like the wiper arm is threaded or somthing?
Old Jul 26, 2006 | 04:01 AM
WeinerSchneitzel's Avatar
Default RE: HELP ASAP
The wiper arms are usually splined like an axle through a hub so once you remove the 2 nuts, they should wiggle off or require light prying (work your way around in a circle with light prying force). Here is a Bentley reference though just so you have it:
Note:
Before removing wiper arms, make sure wiper motor is in park position.
Removing
- Remove wiper blades.
- Pry-off caps (2x) on wiper arms with a screwdriver.
- Loosen nuts (13 mm A/F) -arrows-, but do not remove completely.
- Loosen wiper arms -1- by moving them gently.
- Remove nuts completely and take off wiper arms.
- Remove rubber seal -2-.
- Carefully pry out plenum cover -3- at edge of windshield and lift up.
- Detach washer jet connections on rear of plenum cover -3- and take off cover.
This is for removing the wiper arms and the cover behind it to get to the wiper transmission. Hope this helps.
Old Jul 26, 2006 | 04:58 AM
MeanAudiA6's Avatar
its all good i have it installed.. the wipers were a bitch!!
Old Jul 29, 2006 | 05:55 PM
achTTung's Avatar
you had to take your wipers off to install a boost gauge? What kind of gauge are you installing?
Old Jul 29, 2006 | 07:50 PM
MeanAudiA6's Avatar
i installed the awe tuning vent boost gauge
Old Jul 31, 2006 | 01:25 PM
bvgoosedd's Avatar
Hey how do u like that gauge? 1-10 10 being hot!
Old Jul 31, 2006 | 03:14 PM
MeanAudiA6's Avatar
i love it!! 10 all the way very easy to install after you get the wiper arms off!
Old Jul 31, 2006 | 04:29 PM
Hano's Avatar
i got the vent gauge from awe for s4. i love it!!
Mmspartan
Jun 14, 2011 05:14 PM
zerodegre
Sep 20, 2009 11:33 PM
dejahn23
Sep 22, 2008 07:28 PM
bhunt17
Feb 21, 2008 07:07 AM
silveraudib6
Feb 8, 2008 04:11 PM
