Help with error code PO411
Old Jun 22, 2008 | 07:46 AM
timbo108's Avatar
Default Help with error code PO411
CEL came on, Scanned code PO411. Searched but didn't find a thread. Can anyone tell me what it means, a perhaps a fix?
Headed for the airport today..crappy timing for this
Further searching...maybe secondary air injection..incorrect flow? I'll check for hose/vacuum leaks. Anything else I can check? If need be, should I drive it with the CEL until I can spend more time on it?
Old Jun 22, 2008 | 07:59 AM
beachchair's Avatar
Default RE: Help with error code PO411
P0411 Secondary air injection system. Incorrect Flow Detected.
Old Jun 22, 2008 | 08:16 AM
timbo108's Avatar
It runs during initial start-up to scavenge exhaust right? Sometimes I hear the squeal (winter months). Anything short term that I can do, would it hurt to drive that that? Didn't find any vacuum leaks, no other problems. Car is a 2001 225 with APR chip, cone filter, aftermarket DV.
Old Jun 22, 2008 | 08:32 AM
techbod's Avatar
P0411 = air pump, air valve, air hoses also check the fuses /relay under the hood because the pump might not be working at all
Old Jun 22, 2008 | 08:46 AM
timbo108's Avatar
Thanks,
Any pics of fuse/relay locations? Also trying to track the vacuum line tothe Combi valve..any clues?
Old Jun 22, 2008 | 08:54 AM
techbod's Avatar
[IMG]local://upfiles/12092/41A6235C036B4FAD8CD9F2087B4303EE.jpg[/IMG]
[IMG]local://upfiles/12092/91FB1CC5791A41FE90B4B639F0EF277E.jpg[/IMG]
[IMG]local://upfiles/12092/A1EEA34AB66E4D9EB2D36A09FDE1EF92.jpg[/IMG]
rdltmc3
Apr 16, 2012 06:25 PM
kidhanny
Mar 27, 2012 07:42 PM
tdepirro
Jul 22, 2011 06:33 PM
primetime77
Dec 7, 2007 02:09 PM
xman58
Oct 4, 2007 11:10 PM
