help needed!!!!!!!!!!!!
Old Nov 7, 2007 | 04:45 PM
  #21
cincyTT's Avatar
I'm make believe
Default RE: help needed!!!!!!!!!!!!
With a maf based car your safer with a recirculating valve, but since you have a baileys twin piston dump valve, you will be fine. You have it installed 100% correct. It maybe a little rough at first, but after a couple days it will be perfect.
I just wanted to make sure you were from the UK so i can get my termonalogy correct between us.
  #22
cincyTT's Avatar
I'm make believe
ORIGINAL: ouTTie914
BOV's don't belong on TT's!!
hehe!
A bov releases the air into the atmosphere, and a dv recirculates it.
will you just stop already....PLEASE!!??!!
Old Nov 7, 2007 | 05:04 PM
  #23
m3yer's Avatar
its installed correctly, i was just wondering if it will have lost power, compared to if i had put a new recirculting valve on?
Old Nov 7, 2007 | 05:08 PM
  #24
cincyTT's Avatar
I'm make believe
nope. If it runs like it should, you wont have any problems.
Old Nov 7, 2007 | 05:14 PM
  #25
m3yer's Avatar
ok cheers, so the first thing to do really is to chip it, before getting a boost valve?
Old Nov 7, 2007 | 06:51 PM
  #26
randomloginname's Avatar
No point in adding boost with a chip or diode before you know if you have any boost leaks etc. Get a boost gauge, see the faq in this forum for more info. Make sure you are hitting the psi/bar you are supposed to, same for vac. If that looks good and you are up to date on the maintenace, go for the chip. my .02.
desertsnake1991
Aug 28, 2012 11:07 AM
thenjd
Jan 23, 2008 04:00 AM
raffysaudi
Feb 5, 2007 06:44 PM
GregaXX
Feb 3, 2007 09:37 PM
poloblue22
Aug 3, 2005 11:10 PM
