Hesitation still
Old Dec 29, 2007 | 05:57 AM
outinfront's Avatar
Default Hesitation still
Well I took cincy's advice and put ngk bkr7e spark plugs in-and it cured about 90% of my misfire/hesitation..but a little still remains. Wonder why. Any ideas where the rest of it's coming from?
Old Dec 29, 2007 | 10:26 AM
MeanAudiA6's Avatar
Default RE: Hesitation still
possible N75 and maybe the N249? these are the only things i can think of right now. if you dont have any leaks with the wastegate(itself and hose) and depending on when you are getting the hesitation in and out of boost etc. its great that the plugs helped alot...new coil packs?
Old Dec 29, 2007 | 01:29 PM
cincyTT's Avatar
I'm make believe
you can find the problem if you scan the ecu and pressure test the system. So if its electronic or throwing a code it will show, or if its a charge pipe leak you can find it.
Old Dec 30, 2007 | 12:52 PM
225tt's Avatar
Pressure test, and also check your coilpacks...unless you have already done that. When I had my problem it was only at full throttle and starting at 4k rpms. Do you have vag-com or know anyone who does? I can explain how to check your packs if you do or can get a hold of one.
ianjm
Feb 24, 2010 06:51 PM
eliTTe
Sep 30, 2007 01:06 PM
duburban
Jan 5, 2007 01:51 PM
bugbear
Nov 14, 2005 06:28 PM
bhj0887
Oct 8, 2005 12:09 PM
