HID Problems, arrrrgh!
Old Aug 9, 2008 | 03:49 PM
Audi Addict's Avatar
Default HID Problems, arrrrgh!
I got some new bulbs for my HIDs as they are starting to turn a bit purplish. The main problem is that I replaced the driver side bulb and tried it out. It fired and stayed lit for about 5 seconds and then died. No biggie, I thought. Checked and replaced fuses that had blown, no dice. So I try the original bulb, thinking I had blown th bulb somehow. Again nothing. It will not fire or light no matter what. Can I check the voltage at the bulb socket or is the voltage is to high? Any one have any solutions or advice?
<please, anyone?>
Old Aug 9, 2008 | 04:41 PM
achTTung's Avatar
sounds like an igniter/ballast issue, not a bulb/fuse issue.
Im not much help, I haven't screwed with the HID's much.
Old Aug 9, 2008 | 04:46 PM
Checked and found no ground, but power, so I think I might have ripped the connector loose from the ground.
~Great, looks like I will be pulling the bumper tomorrow to plug everything in correctly
Old Aug 9, 2008 | 06:22 PM
achTTung's Avatar
pulling the bumper isn't too hard, and it gets easier/faster every time you have to do it.
Use a marker and mark where the edge of the bumper sits across the front of the car under the hood so you dont need to screw with it trying to get your lines right when you put it back on.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
