High rpm reading
Old Dec 29, 2010 | 01:01 PM
swerve's Avatar
Default High rpm reading
Well i haven't been here for a while since my TT has been running pretty well for a while , replacing timing belt etc ,new A/C and instrument cluster repair.
The rev counter started reading high which i thought at first was just at idle but now i have noticed its all the time , it now idles at 1800rpm and when driving it shows around a 1000rpm higher than it actually is which is a whole different problem, has anyone had a similar problem, i'm going to check with the vagcom this weekend to see if that can shed some light on the problem, no check engine light and it does not sound like its idling fast.
I'm thinking the rpm sensor but if its that then the vagcom is going to show the same rpm reading as the cluster.
Thanks for any input on the subject.
Old Dec 31, 2010 | 12:39 PM
swerve's Avatar
Cool
Well i checked the rpm with the vagcom and its showing 750rpm which means its not the crank sensor
Old Dec 31, 2010 | 05:15 PM
cincyTT's Avatar
I'm make believe
Where is your needle pointing at when off? It should be right on 0. If its not, remove the cluster, remove plastic cover, pull needle and then move it to 0. Dont mess with any other needles while in there.
Old Dec 31, 2010 | 06:45 PM
swerve's Avatar
cincyTT thanks for the reply, yes the needle is at zero when off, i have emailed Gavin at Modulemaster the person that repaired my cluster in the hopes it can be reset or something.
Old Jan 3, 2011 | 07:31 AM
swerve's Avatar
Smile
Sorry i tell a lie, i checked this morning and you are correct the needle is sitting at 1400rpm so i will let modular solutions know but it sounds like i might be doing like u suggested, move the needle, not looking forward to doing that, i sick of taking that cluster out a meesing with it.
ndinsmore
Sep 22, 2013 09:36 AM
Turbo4me
Jul 22, 2010 04:55 PM
AudiCross
Apr 16, 2010 04:15 AM
staciaann
Sep 28, 2008 05:54 PM
Makaroni1313
Mar 21, 2007 09:30 PM
