Low MAF Reading
Old Apr 13, 2010 | 02:34 PM
AudiCross's Avatar
Default Low MAF Reading
I have a MAF reading at WOT and full boost of around 80-90 g/s of air when it should be up around 170 g/s. I have replaced the MAF, checked for any vacume or boost leaks, and switched out the ECU with a stock one, it still doesnt go about 80-90 g/s of air.
What could be causing this?
Old Apr 13, 2010 | 02:56 PM
AudiCross's Avatar
EDIT: Also, due to this, it is running very lean. P0171 code whenever it is run under a slight load (ie. on the freeway.) Pings heavily under boost, it has good quality 91 oct. gas in it.
Old Apr 16, 2010 | 04:15 AM
AudiCross's Avatar
Bump anyone? this issue caused a melted engine and an entire rebuild... of the 4 shops i have brought it to, 3 of them finally refused to work any more because they are stumped and the last one just wants to guess and make money....
Scaryfatkid
Jun 1, 2010 04:17 PM
Yerfdog006
Mar 17, 2007 08:19 PM
A4_1.8_20v
Jan 10, 2006 01:24 AM
Hecareth
Apr 2, 2005 05:24 PM
blades
Oct 8, 2004 09:04 AM
