cold engine overheated (audi tt)
Old Nov 17, 2007 | 11:03 AM
pitrman's Avatar
Default cold engine overheated (audi tt)
If I crank up a cold car, the icon for overheating starts flashing, as soon as the engine got a little bit warmer, the light just goes off. I just changed the old black temp. sen. for the green one. What can be wrong??
Old Nov 17, 2007 | 11:45 AM
XCLR8TT's Avatar
Default RE: cold engine overheated (audi tt)
Is it the overheating sensor or the low coolant sensor? If it is the latter, the reason is the problems in the coolant reservoir (translucent tank on the pass side of the engine compartment) corrode. You can try cleaning them with a piece of emory cloth attach to the end of a dowel, that should take care of it.
Old Nov 17, 2007 | 01:41 PM
diehlryan's Avatar
could he just be low on fluid? low enough to cause the light but once it warms/expands its showing the right level?
Old Nov 17, 2007 | 02:51 PM
pitrman's Avatar
the icon blinking after cranking the cold engine on is the same like I have on the water temperature gauge.
the part I changed is water temperature sender(green one) and it didnot help
Old Nov 17, 2007 | 05:42 PM
achTTung's Avatar
Like on this list? Its either low level in the coolant reservoir, or a dirty sensor. NOT the one you replaced, its in the reservoir.
ORIGINAL: XCLR8TT
You can try cleaning them with a piece of emery cloth attach to the end of a dowel, that should take care of it.
Old Nov 17, 2007 | 11:36 PM
pitrman's Avatar
yes, it is the 6th icon from top( coolant temp. warning light) Thank you guys for some ideas, Ill check out the sensor in reservoir.
milu30
Sep 21, 2013 07:45 AM
roistonelight
Jun 27, 2011 10:38 PM
uaconnection
Dec 21, 2010 07:30 AM
fireman9585
Jan 12, 2009 12:10 PM
southieA4
Mar 25, 2008 02:14 PM
