How Do You Reset Service Indicator?
Old Mar 30, 2007 | 07:48 PM
AudiOso's Avatar
Default How Do You Reset Service Indicator?
What is the procedure for resetting the service indicator on a TT?
Old Mar 30, 2007 | 08:02 PM
achTTung's Avatar
Default RE: How Do You Reset Service Indicator?
From Audiworld tech articles:
1. Insert your key into the ignition.
2. Push in the odometer reset button, hold it in, and turn the key to the first click.
3. The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
4. To reset, push the clock adjustment **** the bottom of the tachometer.
5. Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
phillip.beattie
Oct 4, 2013 08:37 AM
ChaoticBliss
Mar 14, 2009 09:45 PM
Jedward02
Feb 4, 2009 10:30 AM
converted
Oct 15, 2007 05:36 PM
roncpi
Mar 23, 2006 02:33 PM
