how hard is it to remove the crossover bar?
Old May 12, 2010 | 05:18 AM
hotgrass's Avatar
Default how hard is it to remove the crossover bar?
i think its called the crossover bar, the black bar underneath the oil filter? im trying to do my secondary air pump this wk but i dont have any power tools but just regular tools so im wondering how hard is it to remove?
Old May 12, 2010 | 11:52 AM
cincyTT's Avatar
I'm make believe
Its held on by 3 bolts on each side. Takes maybe 10 mins to remove.
Old May 12, 2010 | 01:26 PM
coachvtt's Avatar
Cincy is correct I pulled mine out all-together because I went with a FMIC and then its not needed!
Old May 12, 2010 | 10:46 PM
MCPaudiTT's Avatar
It's still needed, it's structural. 180's have them, and it is not part of their IC system.
Old May 13, 2010 | 12:51 AM
cincyTT's Avatar
I'm make believe
I wish one of you guys would actually bring proof as to why its so important. If they were that important, a MKIV would have something there also. All those that have removed it have noticed no change, nor would you in a crash.
Old May 13, 2010 | 08:40 AM
coachvtt's Avatar
serves no structural purpose if you take the twin coolers out.
No question! Senseless to keep it and less weight! on the 225. Now on the 180, I have no idea if they have the twin coolers.
Then I assume it is needed unless you delete the twin coolers.
Old May 13, 2010 | 10:59 AM
cincyTT's Avatar
I'm make believe
The 180 uses the same IC piping as a MKIV.
Old May 14, 2010 | 01:45 PM
MCPaudiTT's Avatar
If it were not needed, why did Audi mount it on the 180's, which do NOT need it for any IC purpose? You think they created the parts and paid the money for them, and the labor to put them on, because they felt like weighing down the front of the front heavy car?!
Where's your proof it is NOT needed? The burden of proof is to prove why it is OK to take it out, now why it should be left in...
Old May 14, 2010 | 02:19 PM
cincyTT's Avatar
I'm make believe
Go and look where its mounted and how the pipe is built. Plus, as i have said many a times, if they were THAT important, the MKIV would have one or something similar. No one is telling you to take it off, mines not even within 600 miles of me nor do i care. Its probably still sitting next to my rear counterweight that i also choose not to run. Since neither improve or hinder my situation, ill take the loss of 40lbs and improve my acceleration and mpg
Old May 14, 2010 | 04:54 PM
hotgrass's Avatar
anyways, it wasnt that hard to remove but putting it back was a b!tch! when i removed it, there were some oil that poured out, just enough to soak a rag or two. is that bad? where did that came from?
