IAT temp sensor and Water meth
Old May 11, 2008 | 05:13 PM
MeanAudiA6's Avatar
Default IAT temp sensor and Water meth
interesting question here...does anybody see anything wrong with the water/meth messing with the actual IAT sensor? on both 180s and 225 where people are mounting the nozzles they are spraying towards the sensor...dont know how much of a difference if any if the nozzle was spraying away from it...also any negative side effects to the sensor giving either false readings or slowing destroying the sensor....i found this an interesting question any input
Old May 11, 2008 | 05:50 PM
JettaRedII's Avatar
Default RE: IAT temp sensor and Water meth
whether you spray directly on the sensor or before the tb, it's gonna get wet. Interesting question, but I've never had a problem with it (unlike the problem I had with throttle bodies). time will tell.
Old May 11, 2008 | 06:20 PM
MeanAudiA6's Avatar
yai know its getting wet either way but still might not get as wet one way or the other...main question is if the water/meth is eating the sensor away...you can easily see how the intake temp readings the ECU can see might be off
Old May 11, 2008 | 06:30 PM
achTTung's Avatar
If anything, IAT's would read even cooler, which would make you dump a little more fuel, and you'd still be making power.
Old May 11, 2008 | 06:32 PM
cincyTT's Avatar
I'm make believe
if it read colder, it wouldnt pull timing (if there was any to pull) but that wouldnt cause you to add in any fuel
Dont think you would have any effect on the iat sensor since no one has ever reported it (here or on evolutionm.net where 10x more people run it) and some have ran it for years.
Old May 11, 2008 | 06:34 PM
achTTung's Avatar
figured it was the same as those goofy ricer 'chips' that you either solder to the thermostat or intake. Car thinks its not quite warmed up, and adjusts accordingly.
Old May 11, 2008 | 06:41 PM
cincyTT's Avatar
I'm make believe
iats are only timing based. After that, it goes into limp
wldeyerazr
Jan 7, 2014 10:06 AM
95 A6
Apr 29, 2009 08:32 PM
saga
Apr 10, 2008 11:30 AM
fireman9585
Aug 2, 2007 01:39 PM
Andyrew
Jul 28, 2007 02:12 PM
