I'm getting 16 mpg! AARGH! Does that seem right?
Old Aug 28, 2008 | 10:55 AM
derrat's Avatar
Default I'm getting 16 mpg! AARGH! Does that seem right?
I'm beside myself. Just had all kinds of work done to her. I'm getting a check engine light now that is telling me I need a new CAT. Could this be the reason for the bad fuel economy? What kind of mileage do you get?
Old Aug 28, 2008 | 11:03 AM
theTTkid's Avatar
do you beat on it?, also, new cat? do you have an aftermarket downpipe?
what other work have you had done?
Old Aug 28, 2008 | 11:24 AM
derrat's Avatar
Default No. I'm not a speed demon.
I just had a new timing belt; tensioner; water pump; reconditioned head and new gasket; A bunch of new sensors; Radiator flush. I use 91 octane....
Old Aug 28, 2008 | 11:26 AM
theTTkid's Avatar
check your air filter, make sure thats clean
Old Aug 28, 2008 | 11:50 AM
randomloginname's Avatar
I get 25 mixed mpg on 93 octane with the chipped 225. Your mpg does suck, so I sympathize. Perhaps fuel filter, but also, I would do a throttle body alignment (use the search feature here if you are unsure, basically, turn the key to on and wait a few minutes). I would think that if you havent done one since your work, you could be running less than ideal A:F and seeing lower mpg.
Old Aug 28, 2008 | 12:38 PM
bvgoosedd's Avatar
holy shiate. i get like 32 mpg on the highway at least on curse control at like 75 mph. on average tho tro town i get like 17-19 depends on how i drive lol hope that help. mine is chipped and it's a 225 as well
Old Aug 28, 2008 | 12:55 PM
Wintermute's Avatar
I get like 5-6mpg.
Old Aug 28, 2008 | 02:50 PM
derrat's Avatar
Default Thanks
Thanks for the advise. I turned the key and heard a 'whirrrrr,thunk, whirrrr, thunk' about 4 or 5 times and then it stopped. Hopefully that does it.
Old Aug 28, 2008 | 03:12 PM
Good luck, keep us posted, it helped me after I got a new TIP and some other parts and pieces
Old Aug 28, 2008 | 04:00 PM
2Screwed's Avatar
If you are using reconditioned heads, you might want to check the compression to make sure the valve job was done right. How does the power feel? sluggish or peppy?
