Immobilizer Problem?
Old Nov 29, 2005 | 02:59 PM
RussTT's Avatar
Default Immobilizer Problem?
I have the strangest issue im not sure as to what is causing it...
Basically my key doesnt seem to lock or unlock the car....my doors alarm led's are not flashing when locked and I can only get into the passenger side door with my key the driver side wont unlock. Once inside the car the lock and unlock buttons between the seats wont lock or unlock the doors and the alarm disabler button wont work either.
I can drive the car normally and everything else seems to work fine (lights, fogs, air conditioning, heat, seat warmers, radio, cd player, etc.)
anyone ever have this issue???
Old Nov 29, 2005 | 10:17 PM
AudiTech04's Avatar
Default RE: Immobilizer Problem?
It wont unlock with the remote or manually?
When you open the doors does it register in the cluster display
Maybe looking at a new comfort module
Old Nov 30, 2005 | 12:27 PM
RussTT's Avatar
Well I finally got the alarm system to function now when I manually lock and unlock the doors everything seems to work as it should but the remote still doesnt work so I replaced the battery and now it needs to be reprogrammed.
my only problem is I only have 1 - 3 button key and a valet key is there a way to reprogram my one key without taking it to the dealer?
Old Nov 30, 2005 | 08:57 PM
AudiTech04's Avatar
Try this
Turn ign on with valet key
Insert 3 button key in lock
Turn to lock position and press and hold the lock button for a few seconds
If it works the side marker and parking lights will flash
Old Dec 3, 2005 | 09:33 PM
dankhound's Avatar
You actually press the button 1,2,3,4 times depending on which remote position you want to program. There are multiple postions available in the control module.
Old Dec 6, 2005 | 04:33 PM
RussTT's Avatar
Well I did as said but still nothing happens I think it may be a faulty Comfort Control Module
time to take it to the dealer....
zepher
Jul 1, 2012 10:44 AM
Audistreetracer
May 20, 2012 03:46 PM
timbo108
Jan 7, 2012 02:51 PM
earleyksig
Apr 14, 2009 11:28 AM
drageron
Jun 26, 2006 03:33 PM
