Inside Diameter of the three DV hoses?
Old May 23, 2007 | 01:18 AM
neur0tic's Avatar
Default Inside Diameter of the three DV hoses?
Well, Im swapping out quite a bit of hose and tubing in my engine bay for silicone tubing. Additionally, I'd like to go ahead and order enough of each of the right size tubing to do my own DV relocation with the new hose and tubing I get. Anyone know the inside diameters for those hoses by chance? I assume the hose going to the top of the DV is either 3.5 - 4.0mm hose. I'm not quite sure of the one at the base. looks like 3/4" or 19mm hose. Can anyone confirm or deny either of these?
Old May 23, 2007 | 11:13 AM
cincyTT's Avatar
I'm make believe
Default RE: Inside Diameter of the three DV hoses?
The dv is a 25mm or 1" od, you would need a 25mm or 1"id hose.
4mm sounds about right for the vacuum lines.
fdrifting
Aug 17, 2010 10:28 PM
LKaler
Jun 7, 2010 02:27 PM
Wvjon
Feb 23, 2010 11:49 AM
wkhan69
Oct 13, 2009 10:49 PM
supercat78
Jun 29, 2006 05:00 AM
