intake
Old Aug 23, 2007 | 03:01 PM
Blue01TT's Avatar
Default intake
as of right now my car has a "custom intake" i guess you could say.... the guy that had it before me just put a piece of pipe on the maf sensorthen had it bent and tucked down w/ a filter on the end (kinda like a CAI). I have seen a few guy on herethat have a filterright on the sensorwould that be better than the intake i got. and if so what will i need to do it? what size filter?
Old Aug 23, 2007 | 03:07 PM
cincyTT's Avatar
I'm make believe
Default RE: intake
WHat you have gives the air more time to straiten out before going into the maf. I wouldnt waste the time to change it unless you dont like the look of it.
Old Aug 23, 2007 | 03:43 PM
.clipse's Avatar
SoCal Crew Member
Default RE: intake
^ :: waiting for the velocity stack pitch ::
Old Aug 23, 2007 | 03:56 PM
cincyTT's Avatar
I'm make believe
Default RE: intake
Why spend money on things that dont add hp? If you are going to spend $200 on a intake, might as well get something that performs.
Old Aug 24, 2007 | 12:36 AM
Blue01TT's Avatar
Default RE: intake
well if i was to change it to just a filter on the sensor what all will i need i seen somewhere in another post that you had to cover one vac. line or something w/ a mic. cover to filter the air but other than that is it as simple as removing my pipe and just clamping the filter onto my maf sensor....and covering that hose end
Old Aug 24, 2007 | 12:46 AM
cincyTT's Avatar
I'm make believe
Default RE: intake
If you already are running without a airbox, im sure the secondary air pumps line already has a filter/cover on it. Not sure why you want to change but all you should need to do is take out the pipe and install the filter on the maf.
Old Aug 27, 2007 | 11:51 PM
Smecker's Avatar
Default RE: intake
I did pretty much exactly what you're talking about, Blue. Took the lid off and put a big cone right on the end, and put a smaller one on the small hose. Then I got some angle aluminum from home depot to brace it. Works nice, opened the sound up nicely, seems to help gas mileage too.
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
