Oct 17, 2007 | 12:32 PM
Just want to know what the problem is when my car jerks between 1st and 2nd gear when I accelerate...it doesnt do it when I accelerate slowly...but it does do it when I accelerate quickly...sometimes it doesnt do it at all...so, whats up with that?
Thanks guys...and gals!!!
~Jeremy
Reply
Oct 17, 2007 | 12:38 PM
RE: Jerking...
mods?
Reply
Oct 17, 2007 | 12:42 PM
RE: Jerking...
Faulty DV maybe. Slipping clutch another possibility. I've read about jerkiness when a DV is going out, that's why I threw that out there. Not sure though. Good luck.
Reply
Oct 17, 2007 | 12:54 PM
RE: Jerking...
Same thing has been happening to me, gona check for bad plugs and vac leaks?
Reply
Oct 17, 2007 | 02:35 PM
RE: Jerking...
No mods...I need to have someone check it i guess...whats the DV by the way? (car illiterate)
Reply
Oct 17, 2007 | 02:37 PM
RE: Jerking...
coilpacks or plugs is my guess... sounds like its only happening at WOT.
Reply
Oct 17, 2007 | 04:07 PM
RE: Jerking...
just start with the spark plugs, takes all of 10mins to do and $6-10 in parts. If it was the diverter valve (dv), your car would slow, but not jerk when the boost kicked in.
Reply
Oct 17, 2007 | 04:24 PM
RE: Jerking...
Traction control? lol
If you slam first>second in my car with traction control on it bogs it and makes it jerk. But I'm fwd too.
Reply
Oct 17, 2007 | 08:39 PM
RE: Jerking...
My guess is the coolant temp sensor is malfunctioning causing the ECM to freak out and cause miss-fires. If you have a VAG COM you can monitor the miss-fire counter on data block 15 or 16 i think to see if its missing.
That and you can check the CTS sensor at data block 3 i believe, if it drops to like -40 or something crazy when your driving thats your problem.
Reply
Subscribe
