lambada o2 sensor
Old Mar 26, 2007 | 07:33 PM
TTsteve's Avatar
Default lambada o2 sensor
Does anyone know where the lambada o2 sensor is located? Just got a P0130 code and I think my o2 sensor went out. Thanks.
Old Mar 26, 2007 | 07:41 PM
225tt's Avatar
Default RE: lambada o2 sensor
You should have two, one before your cat converter and one behind, have you done any downpipe mods since you are running the different turbo?
Old Mar 26, 2007 | 08:02 PM
XCLR8TT's Avatar
P0130 is the Pre-Cat sensor which is located on your downpipe between the engine and the firewall. Clear the code and see if it returns. It will probably take 80 mile or so to code again.
Old Mar 27, 2007 | 12:20 AM
TTsteve's Avatar
It does come back after awhile. It seems like the car runs fine when it is cool but after 30 mins or so when the car gets pretty hot then it starts to backfire and then the code comes. I will try changing the sensor before the cat and see if that fixes things. Plus I still need to do the check for the boost leak somewhere. I havent changed anything to the exhaust since the new turbo. Thanks.
Old Mar 27, 2007 | 12:32 AM
cincyTT's Avatar
I'm make believe
you have a wideband car, so your a/f is going nuts since the o2 sensor is bad. A 2000 shouldnt have as bad of a problem since we have a narrowband car. Change the sensor and reset the ecu and you should be fine.
Old Mar 27, 2007 | 12:36 AM
TTsteve's Avatar
Cool, thanks again.
hluker
Mar 6, 2015 12:39 PM
