longest timing belt life?
so how long have some timing belts lasted?
im at 70k+ miles on an original belt... i know its recommended every 60k but as of now replacing it is not an option, my parents said they wont help either until 80k miles which a mechanic once told them...
thoughts?
p.s. - i got my parents to agree to rebuild my engine if it breaks before 80k but i really dont want to have to go through the hassle if you know what i mean
thoughts?
Mine i believe was orginal when i had the engine rebuilt at 105k miles. My brothers was just changed on his passat 1.8t and he was at around 108k last time i checked. His was finally changed since his wp took a dump (better than the tensioner).
It's not usually the belt that is bad. The tensioner or the water pump are usually the first modes of failure.
Personally I wouldn't try to stretch it out that long. The first thing I did when I bought the car was replace the tensioner, belt, and water pump !!! I've heard of belts not even lasting 60k, but like u said they'll rebuild it if the belt brakes......good luck !!!
