low coolant light.....wtf?
Old Apr 21, 2009 | 03:54 AM
xTTx's Avatar
Default low coolant light.....wtf?
I've been getting a low coolant light for a while now, coolant is NOT low so I kinda let it go for a bit and kept an eye on things. Finally I changed the coolant bottle thinking it was the sensor in the bottle....well, nope.
Anyone got any suggestions?
Thanxxx
Old Apr 21, 2009 | 11:13 AM
Neiman45's Avatar
You may have a blocked hose somewhere
Old Apr 21, 2009 | 11:27 AM
xTTx's Avatar
The thing is it only does it once in a while...some days its more frequent but others its not..cluster throwing bad codes maybe? That's why I was thinking it was electrical.
Old Apr 21, 2009 | 08:08 PM
ninjatturtle's Avatar
Member
i had the same problem out of the blue on cold or cool mornings, then just if the car had several hours to cool down. it never looked low. when i got my oil changed they topped off the coolant end of problem.
Old Apr 21, 2009 | 08:14 PM
intake's Avatar
Remove the electrical connector clean it and reconnect. My moms caddy had the same problem and this worked.
Old Apr 22, 2009 | 10:04 PM
xTTx's Avatar
Alright ill try the connector, im an airplane mechanic so maybe I should utilize some of the tools at work, ie contact cleaner, why didn't I think of that ha..
Old Apr 27, 2009 | 02:27 AM
xTTx's Avatar
cleaned the connector with contact cleaner..no luck, still does it. My car is possessed i think too, it throws codes all the time then its fine w no codes, idk whats going on...
Mossyoakglock
Dec 28, 2010 01:13 PM
shady927
Mar 2, 2009 12:23 AM
Ph3N0m
Oct 21, 2008 12:58 PM
Shwabmyknob
Nov 25, 2007 10:07 PM
