MAF tamper proof torx?
Old Dec 17, 2007 | 11:24 AM
vivanov1's Avatar
Default MAF tamper proof torx?
Hey, i cant find a tamper proof torx bit to unscrew the MAF to take it out? does audi have a special type of tamper proof torx bit? pleease help
Old Dec 17, 2007 | 11:27 AM
moeron7's Avatar
Default RE: MAF tamper proof torx?
You can pull them out witha pair of channel locks and replace them with something easier to pul out.
Old Dec 17, 2007 | 11:28 AM
vivanov1's Avatar
whats a channel lock? and where do i find one?
Old Dec 17, 2007 | 11:31 AM
moeron7's Avatar
Any hardware store.
Old Dec 17, 2007 | 11:55 AM
diehlryan's Avatar
You can use needle nose pliers too. Its best to remove the entire maf housing for this.
Check this out:
https://www.audiforums.com/m_481721/tm.htm
Also I picked up a set of tamper proof torx bits from Sears for somewhere between $10 and $20.They were 6point which worked on the original MAF housing but would not on the new maf housing I purchased which were 5point torx.
Old Dec 17, 2007 | 12:07 PM
WishIWasRWD's Avatar
Who takes the time to 3D render channel locks?
Old Dec 17, 2007 | 03:39 PM
rayveedub's Avatar
use a drill and drill out the center nipple. then you can use regular torx to remove. or just use pliers.
Ghostrider II
Aug 25, 2010 09:57 AM
01afour
Feb 6, 2008 02:11 PM
bcart82
Mar 18, 2007 09:30 PM
S_R_N83
Dec 30, 2005 02:38 AM
